I can’t reset the Lamp Meteorite YLDL01YL. I tried to turn on and off five times but I don’t get the “breathing” lights. If I turn on and off the lights too fast, the lamp sometimes does not turn on, it is as if the energy arrived with delay. I made a cable with a switch and connected it directly to a socket, but I did not get any results.
In the way it is, every time I turn on the light, the main changes between warm, cold and neutral white in this order and returns to stay warm. The indirect lights change between blue, red, green and back to blue. When a time passes (I think every half hour) the main light changes (from warm, to cold and to neutral)
Any ideas? I have other 14 Yeelight devices (2 beside lamps II, 2 ceiling lights 600, 4 color bulbs, 4 lightstrips and 2 YLXD01YL 320) and this is the only one with which I have this problem to reset and link.
Thank you.
