No connection with Xiaomi Mijia Bedside lamp (MJCTD01YL) via Wi-Fi (via home Wi-Fi point)
Xiaomi Mijia Bedside lamp (MJCTD01YL, firmware: 1.5.9_0170); program Mi Home version 5.5.6, region selected: China, Mi Account ID 1590632317; home router Mikrotik, home Wi-Fi point settings: WPA2 PSK encryption type, AES CCM encryption; lamp control from the smartphone OnePlus 5T
  1. After acquiring Xiaomi Mijia Bedside lamp (MJCTD01YL) connected to Mi Home via home Wi-Fi point and updated to firmware: 1.5.9_0170
  2. Xiaomi Mijia Bedside lamp (MJCTD01YL) works and is connected via a home Wi-Fi point, but is not available to control
Under what conditions does the Xiaomi Mijia Bedside lamp (MJCTD01YL) connect and control:
Smartphone OnePlus 5T, program Mi Home version 5.5.6, selected region: China, mobile Internet
Under what conditions is there no connection to the Xiaomi Mijia Bedside lamp (MJCTD01YL):
Smartphone OnePlus 5T and Xiaomi Mijia Bedside lamp (MJCTD01YL) are connected via home Wi-Fi point, the program Mi Home version 5.5.6, region: China
Please help with solving this problem, thanks;)
Could you have a try with Yeelight application to see if “Lan Control” is enable?
I use only MI Home software, the Yeelight installed installed recently and only authorized via MI Account ID without adding devices. In the Yeelight software, the “Lan control” option did not include.
After the creation of the topic on the forum there happened something wonderful and the lamp was connected to MI home through the home Wi-Fi point :smiley::hugs::+1::v::metal:
dingyichen thanks :wink:
You are welcome, good to know it works for you.
Make sure you select the same server with Mihome.
Thanks for the information. I will install a single region in the software Mi Home and Yeelight.
