Yeelight color bulb electric issues
Last time I getting often turn off the electricity in the apartment. Every time the light turns off and then turns on with the bulbs on full bright, app saying to reconnect them. Is it possible to set by default, if the switcher always on, as disable devises to avoid a winding light? This is so annoying when bulbs act like this after turned off electricity in my home! Thanks!
Yes, you can set default state from power outage. From Yeelight application, click “right-bottom button” in the control view, you will see option of 'Default State".
Thank you so much, i will try this!
