suddenly it dosen’t work power button, reset button. also can’t connect application, can’t find a DHCP. just blinking all days. how can I fix it?
Hi Bros,
My desk lamp has same issued, it’s blinking continuous all days. Do you have any solution for that?
Thanks,
Does the lamp version support Homekit? How about reset it?
Same happened to me. Light is blinking. Can not stop it.
Any suggestions?
same problem, i have had my smart LED Desk Lamp for more than a year or even two now and today (out of nowhere) the lamp turned off and when when i diconected and connected the power cable it started blinking fast 16 times then stopping for a second and then blinking again. I’ve tried to reset it but the reset button won’t do anything, the power button doesn’t work either. It’s like i can’t do anything. Also I can’t find any information about this anywhere but here, so strange. Please help us, this lamp is expensive and should not stop working out of nowhere like it did.
I just found out what the problem is when this happens, the problem isn’t in the lamp itself but in the power adaptor. If you listen closely you can hear a repeating sound inside the adaptor when it is connected to the lamp, which means that it is not working properly (it is giving power in a periodic manner and not continuosly, causing the lamp to blink) . If you can get another one or a similar adaptor with the same output port then the lamp will work again. I hope I was clear, thanks.
