How to use the Yeelight bulb color without internet?
I’m having problems with internet connection, my WiFi is working correctly but I can’t control the lights if there’s no internet, how can I control them locally? without internet connection?
I have smart plugs (TP-Link HS100) that work with or without Internet, I should be able to control the lights without internet if they are connected to my WiFi Network.
i think if you enable “LAN control” you can control bulbs without internet.
This option enable also control by third parts app
LAN Control is activated but I still can’t control the lights when Internet is down, how can I control the lights without internet connection? just local WiFi?
You can Connect ti bulb only with a Wi-Fi connection, lan o wan
how?
What exactly do you want to do? Control the when at home, or when away from home?
If at when AT home - you can use 3rd party software which works great, ie. Home Assistant, OpenHAB, Domoticz…
