Yeelight ceiling light doesn't work after changing wifi company and apt.
The light doesn’t work even with the wall switch, can anyone help?
I’m using Singapore server and tried to reset by turning on and off but nothing happens.
I also heard that when changing wifi someone suddenly faced connection failed with error 651 which is causing the problem. You can try resetting the wifi.
