Is Yeelight ceiling light suitable for toilet / bathroom use?
I use My Color Bulb in the bathroom with A Bedroom lamp over it.
Works great
It should work without much problem but do take note if you want to use wifi. The signal might be weak as there is a lot of interference in this area and the walls are also thicker in terms of materials used as water-proofing will be needed.
