Lets for example say that I via voice google voice command say “set the LIVING ROOM light to 50%” I could with just one command set the light in the living room to 50% if I could have an command saying
Hi, Coasterli.
Is it possible to add On/Off status of the YeeLight as the trigger for Tasker?
For eg, If the lights are on, I can have a notification created to remind me that the lights are on if I am not at home. Lights will be on automaticallyafter power outage.
The Tasker integration via Yeelight app plugin is not stable. I have a Tasker profile for Yeelight autostart if I’m at home 30 minutes before sunset. But on 3 of 6 days it doesn’t work. In such case I have to open the Yeelight app, turn on the bulb manually and then Tasker can control the Yeelight again. One day later it is possible that it is working automatically only with Tasker, but it will broken soon (e.g. 2 days later I have to turn it on again manually). Is there another possibility? E.g. with intent call in Tasker or completely without Yeelight app, with directly communication from Tasker to the Yeelight with http request or something similar?
Doesn’t work for me with Send/Expect 2.2.5. Neither in Tasker as plugin, nor standalone.
IP and Port were correct, because I have scanned it with the Yeelight Android Demo with search function.
Even the Chrome Plugin retrieves the same IP and Port and connects successfully.
I have tried different JSON, but nothing happens.
{“id”:1,“method”:“set_power”,“params”:[“on”,“smooth”,500]}
{“id”:1,“method”:“toggle”,“params”:[]}
{“id”:1,“method”:“set_bright”,“params”:[1,“smooth”,1000]}
