I’ve been trying to set “use custom state”, but I always get a “save failed” error, although I’m able to control the light from the app (on/off, change brightness, etc).
iOS or Android?please tell me your user id and device detail.
Hi, i tried yeelight app with android 6_0_1 and 5_0_1. Both of them get same error. (“Save to failed”).
userId/mi id= 1759198867.
(I tried changing server, doesn’t work.)
I have the same issue. iOS and Android versions are the same. It fails. It happened after the firmware update.
I found the solution. Because of Turkey daylight saving time difference, you should change the phone clock ±1 hour. Then
restart.
