Hi, i have a second RGB Strip and somehow while “number one” worls perfectly , number two is not allowing me to connect, i go through the motions , and when i see the “clock” it goes to 25% and then times out.
Any TIP on how to change that ?
hi, which server do you connect?
have you tried Singapore?
yes as i am using Alexa , i cannot get these connected
can you find you strip in your router’s DHCP list?
i will search for that info, i see my first one without a problem and it works.
I will get back to you
