Today i have received my new Mijia Bedside Lamp 2, and I have the following problems:
1- Can´t disable night mode and control Lan, they appear again after some time, specially if i disconect the lamp from the wall.
3- I can´t see the option to set a default light like in other yeelight products.
Are you using Yeelight app?
Yes, yeelight App 3.0.02 for android. Control Lan is not responding, i can´t disable it. When i turn the lamp on for the first time it was already enabled. I have the latest firmware 1.4.8_150.
Yeelight App 3.0.02 uninstalled and reinstalled.
When you unplug the Bedside Lamp 2 from the wall, the next time you turn it on, Control LAN is activated and I can´t turn it Off. Please fix that.
You mean LAN Control? You need to refresh the page in order to see the latest status of that option.
It doesn´t work. It doesn´t respond. It´s enabled again and again after unpluging the lamp from the wall.
Steps to reproduce:
1.Unplug the lamp from the wall. And wait until it appears as disconected in the yeelight app.
2.Now plug the lamp and turn on.
3.Go to yeelight app and you will see Control Lan as enabled and you can´t disable it.
Also I can´t set default colour. That option is missing. Take a look.
Night mode also turns on when it want.
Mi Bedside Lamp saves light state automatically, it has different logic with other devices. So there’s no default light within it.
I test it with my own lamp, it works well. I will have a try with others in our lab to take a look at it.
jlmcr87:
Steps to reproduce:
Steps to reproduce the LAN control problem:
1.Unplug the lamp from the wall (removing the power adapter). And wait until it appears as disconected in the yeelight app.
Different logic? With your new system I can´t change the colour because I lose the default light colour. So please add the option.
Are you going to add the option to set a default light in the mijia Bedside Lamp 2 in future updates?
Because the way It is now if I change the colours, i lose the colour i want.
And please, fix the control LAN because everytime time i unplug/plug from the wall chord, its enabled everytime.
And the last thing…as I said, i dont know if my Lamp is faulty but the red colour is not red and It is very white. i can hear a buzz sound coming from my Lamp when i select this colour.
Please weiwei, tell me something.
