Light group - automation - no favorite colors available
I have a light group in MiHome with 2 RGB led bulbs and 1 light strip.
I want this simple automation. When the occupancy sensor finds movement in the dark, turn on the light group to full white light at 100%.
I need to use the light group because only the light group provides the “turn on and set light” option inside automations. The individual bulbs or strip do NOT.
The problem is when I select the turn on and set light option it gives me only the pre defined scenes (sunrise, sunset, romantic, home etc) and it does not display my favorite colors below as it should.
I have saved my preference as a favorite color and I’ve done this from each bulb and the led strip separately although I know that once should be enough.
Solutions?
Thanks.
Someone with any ideas?
