How to reset Yeelight RGB bulp after reach maximum user
Hi… I need info :
  1. How much device max can connect to 1 bulp.
  2. How to reset bulp after reach max user. Because when i install to my android device. i have notification “90% to max user”
  3. Is there any trick to connect Yeelight to ADSL + handphone Android.
    Because right now i using my other handphone as hot spot. So i can see set up status connect if there is only one device connect to hot spot until 70%. It would be failed connection time out. If the status 2 device connect to it will be successfull. But how can i do it to ADSL modem to see status connection?
Im on Indonesia using Indihome as router ADSL internet provider.
Thank you
