你好
你好我是用 home Assistant 來實施 yeelight 白色燈泡與 amazon echo 聯動,turn on, turn off 及 dim 功能可正常使用,但是如果用yeelight app 或用小米智能家電網關,開關後,在home assistant state 不能同步燈的開關狀態,這個問題在 home assistant 群組幾多個月也未必能解決。能否看看這個yeelight.py 程序上有沒有可以解決的方法。
群組
程序
Support for Yeelight lights.
import socket
import voluptuous as vol
import logging
from urllib.parse import urlparse
from homeassistant.components.light import (
ATTR_BRIGHTNESS, ATTR_RGB_COLOR, ATTR_COLOR_TEMP,
ATTR_XY_COLOR, SUPPORT_BRIGHTNESS, SUPPORT_RGB_COLOR,
ATTR_TRANSITION, SUPPORT_TRANSITION,
SUPPORT_COLOR_TEMP, Light)
import homeassistant.helpers.config_validation as cv
import homeassistant.util.color as color_util
Map ip to request id for configuring
_CONFIGURING = {}
_LOGGER = logging.getLogger(name)
REQUIREMENTS = [‘https://github.com/jjensn/pyyeelight/archive/v1.7.zip#pyyeelight==1.7’]
ATTR_NAME = ‘name’
DOMAIN = “yeelight”
DEFAULT_TRANSITION_TIME = 350
DEVICE_SCHEMA = vol.Schema({
vol.Optional(ATTR_NAME): cv.string,
vol.Optional(‘transition’, default=350): vol.Range(min=30, max=180000),
PLATFORM_SCHEMA = vol.Schema({
vol.Required(‘platform’): DOMAIN,
vol.Optional(‘devices’, default={}): {cv.string: DEVICE_SCHEMA},
vol.Optional(‘transition’, default=350): cv.positive_int,
}, extra=vol.ALLOW_EXTRA)
SUPPORT_YEELIGHT_LED = (SUPPORT_BRIGHTNESS | SUPPORT_RGB_COLOR |
SUPPORT_COLOR_TEMP)
def setup_platform(hass, config, add_devices_callback, discovery_info=None):
“”“Setup the Yeelight lights.”""
ylights = []
ylight_ips = []
if discovery_info is not None:
ipaddr = discovery_info[1] #
device = {}
device['ipaddr'] = ipaddr
device['name'] = discovery_info[0][-8:]
device['id'] = discovery_info[0]
device['transition'] = DEFAULT_TRANSITION_TIME
ylight = Yeelight(device)
if ylight.is_valid:
ylights.append(ylight)
ylight_ips.append(ipaddr)
else:
for ipaddr, device_config in config["devices"].items():
device = {}
device['name'] = device_config[ATTR_NAME]
device['id'] = device_config[ATTR_NAME]
if 'transition' in device_config:
device['transition'] = device_config['transition']
else:
device['transition'] = config['transition']
if ylight.is_valid:
add_devices_callback(ylights)
class Yeelight(Light):
“”“Representation of a Yeelight light.”""
# pylint: disable=too-many-argument
def __init__(self, device):
"""Initialize the light."""
import pyyeelight
self._name = device['name']
self._ipaddr = device['ipaddr']
self._id = device['id']
self._transition = device['transition']
self.is_valid = True
self.bulb = None
try:
self.bulb = pyyeelight.YeelightBulb(self._ipaddr)
except socket.error:
self.is_valid = False
_LOGGER.error("Failed to connect to bulb %s, %s",
self._ipaddr, self._name)
@property
def unique_id(self):
return "{}.{}".format(self.__class__, self._id)
@property
def name(self):
return self._name
@property
def id(self):
return self._id
@property
def transition(self):
return self._transition
@property
def is_on(self):
"""Return true if bulb is on."""
return self.bulb.isOn()
@property
def brightness(self):
"""Return the brightness of this bulb."""
return self.bulb.brightness
@property
def supported_features(self):
"""Return supported features."""
return SUPPORT_YEELIGHT_LED #
def turn_on(self, **kwargs):
"""Turn the bulb on"""
transtime = 0
if ATTR_TRANSITION in kwargs:
transtime = kwargs[ATTR_TRANSITION]
elif self.transition:
transtime = self.transition
#_LOGGER.error("transtime %d",transtime)
if not self.is_on:
self.bulb.turnOn(transtime)
if ATTR_RGB_COLOR in kwargs:
self.bulb.setRgb(kwargs[ATTR_RGB_COLOR], transtime)
elif ATTR_COLOR_TEMP in kwargs:
self.bulb.setColorTemp(kwargs[ATTR_COLOR_TEMP],transtime)
elif ATTR_XY_COLOR in kwargs:
self.bulb.setRgb(color_util.color_xy_brightness_to_RGB(
kwargs[ATTR_XY_COLOR][0], kwargs[ATTR_XY_COLOR][1],
kwargs[ATTR_BRIGHTNESS]), transtime)
if ATTR_BRIGHTNESS in kwargs and ATTR_XY_COLOR not in kwargs:
self.bulb.setBrightness(kwargs[ATTR_BRIGHTNESS],transtime)
def turn_off(self, **kwargs):
"""Turn the bulb off."""
transtime = 0
self.bulb.turnOff(transtime)
@property
def color_temp(self):
return self.bulb.ct
@property
def rgb_color(self):
return self.bulb.rgb
