Yeelight Color Bulb
Firmware version: 1.4.2_0061
I send discovery request to 239.255.255.250:
M-SEARCH * HTTP/1.1
HOST: 239.255.255.250:1982
ST: wifi_bulb
MAN: "ssdp:discover"
MX: 3
And I get a response (491 bytes):
HTTP/1.1 200 OK
Cache-Control: max-age=3584
Date:
Ext:
Server: POSIX UPnP/1.0 YGLC/1
model: color
fw_ver: 61
support: get_prop set_default set_power toggle set_bright start_cf stop_cf set_scene cron_add cron_get cron_del set_ct_abx set_rgb set_hsv set_adjust adjust_bright adjust_ct adjust_color set_music set
power: off
bright: 1
color_mode: 1
ct: 4000
rgb: 1638655
hue: 359
sat: 100
There is a set
value in the support
header, but no set_name
value. Looks like it’s just trimmed…
The device is working correctly (via Yeelight app too), set_name
method is working, set
method returns "method not suppported"
error as expected
Is this normal?
