Hello, I suggest to create a control like the one that it have the Desk Lamp. To control all the devices, even the Bedside Lamp. You can use it to: One Tap, Double Tap, Rotate, Press & rotate.
Example:
- One Tap: Turn On
- Double Tap: Change Mode
White Mode: - Rotate: Change Brightness
- Press & rotate: Change Temperature
Color Mode: - Rotate: Change Brightness
- Press & rotate: Change Color
Flow Mode: - Rotate: Change Brightness
- Press & rotate: Change Speed
Tell me to see if you think it’s a good idea to not depend on the smartphone to control for exaple the bulbs or the lightstrip that they don’t have any button or control.
