Hello, I have a Yeelight Bedside Lamp 2 (Mijia), I want to set a default Color and brightness whenever a turn on the lamp manually, either using the button or the app for android.
So I use the configuration for this turning off the “Remember last state” switch, and setting a custom color and brightness as default,
The problem is that when I turn the lamp on after any scheduled event, it turns on remembering the last state of the lamp of the scheduled event, and ignoring the default color and brightness I chose. So turning off the “remember last state” switch is not working.
Could you please fix this behavior?
Thanks in advance.
