I’m really stuck!
I have a Bedside Lamp 2 (WiFi). I have successfully connected my lamp to my first home network. But once I went to another place, I stuck at setup method. I’m trying to connect to absolutely different WiFi. My Yeelight app is doing something with my lamp, but after 100% of installing I have “Connection timed out”. This WiFi is connected to internet. Then I checked my WiFi for devices and observed that my lamp connected to WiFi, but I still can’t use it. I have reset it so many times and done it multiple times.
I have Xiaomi MiWiFi 3 routers on BOTH places, but I can’t setup my lamp to the second DIFFERENT router.
MY MI ACCOUNT ID: 1584161746
Updated 02.01.18
Well, I came to my old WiFi place and… My lamp can’t connect to it. YES, I HAVE RESET MY LAMP MULTIPLE TIMES
So, my lamp now can’t connect to any network. Successfully connects to WiFi, but the app says “Connection timed out”
Similar problem here. I can’t even connect properly to my first router. The connection keeps timing out, or it works for a little while and then it just suddenly stops working again.
I do have this problem for now it is solved on my end just make sure that it is in 2.4ghz and not mix Wi-Fi with 2.4 and 5ghz. And do select one of the wifi channels example 11
So here’s my update. I switched to Singapore server and find lamp. I have deleted it and it reconnected successfully, but I can’t connect it to US servers even after reset
