How can ich connect the temperature sensor with the lamp? Using chinese server now, so I found the lamp inside the mi home app, but i can not use the lamp as a gateway Server. How does it work?
Thanks you.
Which temperature sensor do you have? I am not sure if gateway supports it.
Hi
It is called mijia temperature sensor using ZigBee Script. See foto nearby.
I ordered the Sensor because in an other post you told us that it will work
source Yeelight Bedside Lamp as Gateway
I believe the sensor you bought works with Xiaomi Gateway, wheres the Bedside Lamp is the BLE gateway which act as a gateway for bluetooth devices.
@thorrellius Yes, you are right.
This picture shows supported devices.
You can find these information from MiHome.
Hi, I got the bedside lamp 2, but it doesn’t show up as BLE gateway. Both the lamp and the sensor are on the same server and show up with latest firmware. the lamp firmware - 1.2.8_0029; sensor - 1.0.1_0066
hi there. did you had any update on the BLE on the bedside lamp 2? i have one and the BLE doesnt work.
Hey, unfortunately, it turns out that the lamp doesn’t support BLE… so i opted for the alarm clock which does have BLE…
