What is the minimum distance of 2 screw hole is required?
46mm
Thank you for your reply. I am going to buy the ceiling light. I measured the existing screw hole from centre to centre which has 50mm. Enough to install this light without drilling any new hole, isn’t it?
Yes
I have existing screw holes and the distance is 18cm. What is the maximum screw hole distance?
Over 20 cm
