I suddenly had my light dissappear from the Yeelight app and I wanted to reset it in order to add it in the app again, but after I reset it using the five times on/off method the light pulsates as it normally does after resetting it, but now at the end it blinks once. The app can’t find the light. I think the blink at the end has something to do with it. All help appreciated.
We have fixed a bug that may cause ceiling light offline, the firmware is still in QA and will be released in two weeks. Do you have any interest to do a beta test? If yes, please provider your Mi account, i will add you to our ceiling light beta test list. So you can update firmware of your light.
I am interested for sure! My Mi account is magicmalnsk@gmail.com.
How can i update the light if I can’t connect to it? It’s not showing up when i reset it. The wifi of the light shows up in my wifi list though.
I have added in ceiling firmware beta test list. You can’t update firmware if the device is offline, so please connect it again after you reset it. (If you have problem with connection, please use another phone, setup a hotspot with your mobile network, connect ceiling light to it and update the firmware.)
If you have other Xiaomi bluetooth devices that support gateway, you can get information of ble devices through network/mobile 4G.
For example, there is one device that support gateway from https://www.mi.com/mj-humiture/?cfrom=search, which is a bluetooth based device and has ability to know temperature and humidity of an environment. As you know it based on bluetooth, you can connect it with ble from your phone and it has a distance limit. So if you also have a Yeelight Ceiling light with gateway support, you can get temperature infomation from anywhere if it has network. (Yeelight ceiling light is a bluetooth/wifi multi-module device). Hope this can help you to understand.
How about other BT products from the mi line? Like the sensors for temp and toothbrushes? And how do i add them to this light gateway? Can i use the light in yeelight app and also in mi home app?
