I just got my new Yeelight color bulb and I’m having a hard time trying to set it up. It blinks rapidly on white and then cicles through them colors and then the same thing again. It appears on the wifi list while it is displaying colora but there isn’t enough time to connect before it disappears from the wifi…
I did the set up with a white bulb a few weeks back and it worked out just fine, so i dont think im doing anything wrong.
Yep… it is still flashing rapidly on the white color and then, when it cycles through other colors, it appears on the wifi list until it flashes on white again, disappearing from the wifi list. So it doesn’t have time to finish the configuration before it turns off the wifi once I connect it to my iPhone.
It blinks 4 times at white (not as fast as before), then cycles through the colors and repeat.
It says impossible to connect with yeelight_color wifi, however it will connect if I click on the yeelight_color wifi while it displays the colors, but it gets stuck at 25%.
