I just bought a Yeelight Lightstrip Color yesterday. I installed the Mi Home and Yeelight App, once I updated the firmware to the current version I lost the red color completely. Now it only shows green and blue manually and the Yeelight App shows shades from green to blue, no longer able to show yellow, red, pink, purple etc.
Is there anyway to fix the problem? It worked fine before the firmware update.
Tell me what could have happened with the rgb tape. Does not shine purely red when you select a red color in the palette. although the red LED is lit, but it is lit together with green. and generally it is noticed that red and green constantly burn, but the intensity of the glow changes each LED. The blue LED turns on correctly, as the color is corrected. Firmware 1.4.1_40
Is there any other solution to this? Same thing happened to me and I would like to try all means to fix the issue before resorting to buying a new set.
