Envoi d’une requête ‘ping’ sur ot.io.mi.com [120.92.96.244] avec 32 octets de données : Réponse de 120.92.96.244 : octets=32 temps=290 ms TTL=44 Réponse de 120.92.96.244 : octets=32 temps=277 ms TTL=44 Réponse de 120.92.96.244 : octets=32 temps=277 ms TTL=44 Réponse de 120.92.96.244 : octets=32 temps=277 ms TTL=44
Statistiques Ping pour 120.92.96.244:
_ Paquets : envoyés = 4, reçus = 4, perdus = 0 (perte 0%),_ Durée approximative des boucles en millisecondes :
_ Minimum = 277ms, Maximum = 290ms, Moyenne = 280ms_
I have on the other hand, successfully installed the standard “YEELIGHT LED Bulb” without any problem.
DISABLE bluetooth on your iphone, then try to add ceiling lamp again. In the first page when you click NEXT button, there will be window popup to remind you enable bluetooth, click other area to dismiss that window and then click NEXT button again. Then you will be able to connect ceiling lamp in same way as color bulb. Try this and let me know!
