hello,
a few months ago i got my Yeelight LED Bulb as a present, back then i could not connect to it with my galaxy s6 edge, my boyfriend could and shared it with me.
After my phone didn’t work anymore I got a new one (also galaxy s6 edge), i could not connect to my Yeelight LED Bulb, too.
My boyfriend could and tried to share it with me, it still didn’t appear in my app. I changed the server several times (Germany, Singapore, China and USA), it didn’t help.
I have no clue why I cannot connect to it…
Please make sure you select the same server with your friend. And in the slide menu, there is a message center to accept the share.
yes, it didn’t appear in the message center, too. but we’ll try this again in a few days.
but why can I not connect to my Yeelight on my own? it can’t be right that my boyfriend have to share it with me everytime i want to connect to a new Yeelight.
anyway I am stuck at the first step…
If your friend can find the AP name in his phone, I think there must be something wrong configuration with your phone.
hello again,
my boyfriend could connect to my lamp easily and also could share it to me now without any problems!
