I have the same problem. After two weeks, my Yeelight RGB stop working. It can’t Connect with the app and i can use It only offline. Also, After 10 min Is Turned on, It becames Crazy and starting to turn on/off continiusly. Anyone Can help me?
Did you use the bulb with a dimmer? Or did you put the bulb in a small place? The flicking is normally caused by overheat.
If not, please contact your reseller for a refund or replacement.
