Yeelight YLDP02YL, worked for a while, and it decided to stop, so I figured id try to reset, but it wont reset. It’s disconnected, and doesnt turn on. Just flashes for a split second when the switch is flicked on or off. How can I fix it :<
Could you turn on the bulb?
nope, doesnt respond to anything other than that split second flash when the switch is turned on and off
Do you have other lamp socket? I encountered the same issue like you, and the bulb return back when i changed a lamp socket.
no, unfortunately, i only have one lamp that is e27. Every other socket is bayonet.
I’ll try purchasing an adaptor
