Would be interesting to have the possibility to switch the bulb using physical switch, but keep it connected to the power.
Currently if the bulk is turned off from the App you can use the physical switch to turn it on (2 times on/off).
There is any possibility same way to torn it off? I would recommend to use same pattern but to program it instead of “turn on” to “tooggle”.
Regards,
Ghenadie.
