(A bug of Mi Home about led device)灯组在米家设置智能化,如有延时设置,则会出现执行故障!
出现问题设备:yeelight mesh筒灯/球炮
Problem:yeelight mesh led device
APP:米家,v4.12(前一版本同样问题)
APP:Mi Home,v4.12
硬件设置:组建灯组
Set:device
智能化设置:有人移动且亮度暗+(灯组)开灯+延时(x分钟)+(灯组)关灯
Automation:Motion detected and indoorbrightness +Turn on+ 1m later +Turn off
日志:执行失败,请重试,异常错误。
Logs:Taskfailed,try again,Error.
经测试,菲利普睿智筒灯组建灯组后,使用上述智能化设置,会同样出现:执行失败,请重试,异常错误。
I had tested the phlips’s led,use the same setting,the same error.
另,将智能化设置修改为:有人移动且亮度案+灯组开灯;x分钟无人移动+(灯组)关灯两组智能化,则开、关灯都能正常执行智能化指令。
If you change the setting,delete the “1m later” and “turn off”,everything is OK.
是米家的bug吗?请工程师测试该错误场景!
Is this a bug of Mi Home?Could you rebuild it?
yeelight的工程师不在吗?
我也遇到这个问题呀
