Splitting and Extending
I wondered if i could split the yeelight lightstrip along the scissor lines and use this lead:
C-able 100ft(30.5m) 22 AWG 4Pin RGB Wire Extension Cable with Spool, Led Lights Wires Strip Extend Wire for 5050 3528, with 8PCS RGB Led Strip Connectors https://www.amazon.co.uk/dp/B07FDW4M89/ref=cm_sw_r_cp_taa_m2HpCb8KQEHTQ
I plan to separate and hopefully use as undercabinet lighting in my kitchen.
TIA
How did it end up? It works? I plan to do the same thing.
Hi!
As VasekD asked - did it work? I’m looking for a similar solution. Need to extend between to kitchen cabinets. Bying Yeelight normal extenstion won’t do it for me.
Hope for an answer and how-to.
Br Mulle
