It has stopped working. It doesn't reset, it doesn't do anything
I have been use it from time to time for exactly a year now, and suddenly it has just stopped working.
I was using it normally one day when the next day it just stopped working. It’s not detected on my phone, on my router… anywhere.
Neither I seem to be able to reset it. I’ve followed the instructions: unplugged, hold the button, plug it back, wait until it start flashing in colours… Nothing happen. It never starts flashing in colours no matter how long I hold the button.
Its little led indicator is also off. There is no light coming out of the manual controller.
Is this just dead after a really short live?
Please make sure it has a good power supply.
It has a good power supply. I tested the socket with different devices and I haven’t had an issue with any of them… so that doesn’t seem to be the problem I’m afraid.
You should not hold the button. You should turn the light on, wait 2 seconds then turn off. Repeat this 5 times and it should reset.
You might want to check this tutorial:
https://www.yeelight.com/support/41
Thanks for your suggestion, but I believe you got this wrong. Those instructions are for a bulb, but in my case I’m dealing with the lightstrip (color) with follows these instructions for resetting: https://www.yeelight.com/support/11
I’m still having the same issues.
Excuse me, the tutorial I’ve sent you was indeed for a bulb. Wait for a staff member to respond.
