cannot connect
Hi
I have 9 yee light colour bulbs had successfully installed them and they were working just fine.
yesterday it stopped working, it would not connect to my phone. i restated my router, updated the app, restarted my phone but its still not working.
then i deleted my app, and re-installed from the ios app store, i had to reset my bulbs, but every time i try to connect, the connection fails. pls help.
Do all of your bulbs not work?
