Xiaomi Bedside Lamp with latest firmware 1.5.9_0169 not working properly.
I have noticed 3 issues:
- If I turn on/off, change colour, brightness etc. on Yeelight/Mihome app or by physical button on the lamp then status in Homeassistant is unchanged.
- I cannot use in automations “color_temp:”, hs_color", “xy_color”. If I use any of this in automation - lamp just do not turn on. I can use only rgb_color and brightness
- If i set rgb_color :[255,255,255] and brightness: 255 Bedsde lamp light is very dim. I must use yeelight app and in “white color” section move circle to bottom right corner to make it bright.
