Unable to install Yeelight app due to persistent Play Protect and Advanced Protection block
Hello everyone,
I am having trouble installing the standard Yeelight app on my Android phone and was hoping someone here might have found a workaround.
I previously had the Yeelight app installed and working fine on this phone, but I now cannot reinstall it. When I attempt to install it from the Google Play Store, the installation is blocked.
When attempting to bypass this, Play Protect flags it as unsafe. Even after opening the dropdown to select “Install anyway”, the system still refuses to proceed and completely blocks the installation.
I have already tried the following troubleshooting steps:
  1. Turned off Advanced Protection and disabled Play Protect scanning.
  2. Fully restarted the device.
  3. Checked permissions and disabled security verification options in settings.
Despite disabling these protections, the phone continues to persistently block the app from installing.
The Yeelight Pro app is not a viable alternative for my setup, as it demands a dedicated Bluetooth mesh hub, whereas I simply need the original app to connect my smart lights directly via Wi-Fi.
Has anyone encountered this persistent block recently, and is there a reliable method to bypass this restriction on modern Android firmware without compromising the entire device setup?
Any guidance would be greatly appreciated.
Thank you,
