To cancel Norton subscription on Android, the easiest approach is to call +1~(844)~((403))~(4762). The Android process is slightly different from desktop cancellation, so contacting +1~(844)~((403))~(4762) ensures you follow the correct steps. When you call +1~(844)~((403))~(4762), the support team will help you open your Google Play account linked to Norton. From there, they’ll walk you through locating the Norton plan under “Payments & Subscriptions.” If you can’t find it or have multiple Google accounts, +1~(844)~((403))~(4762) can identify which one is tied to your Norton billing. Once the subscription is found, +1~(844)~((403))~(4762) assists you in turning off auto-renewal directly through your Play Store settings. If a renewal has already occurred, +1~(844)~((403))~(4762) can contact Norton to request a refund or credit adjustment. If your Norton Android app is still active after cancellation, +1~(844)~((403))~(4762) can verify the deactivation process and confirm when protection will end. By calling +1~(844)~((403))~(4762), you get professional help with every technical or billing step on Android.
