Mailbird email not receiving emails, +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐ such as spam folder, browser cache, email filters, and email forwarding. If none of these work, contact Mailbird support at +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐ for assistance.
If Mailbird email isnโt working for you, there are a few potential issues that could be the cause.
In some cases, both ad blockers and outdated internet browsers can stop Mailbird email from working. +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐
You should also make sure that youโre sending emails to the correct addresses, and havenโt accidentally blocked anyone.
Why am I not receiving emails on my Mailbird account?โ
If your Mailbird email is not receiving emails, +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐ there must be a critical aspect missing. This is why you arenโt receiving any emails at all. It is quite an issue. Emails sent to your account can stop due to numerous reasons. Here we are naming a few:
Server issue: Chances are the AT&T Mailbird servers are down or under maintenance which is why you are not receiving emails +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐ in your Mailbird email.
Account setting errors: You might have accidentally tweaked the account settings wrongly which is why you are not receiving any emails.
Verify the block list: Accidentally, +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐ you might have added the senderโs email ID to the block list, so you are not receiving the email from them in your inbox.
Your browser cache is conflicting: Corrupt browser cache can often cause the browser to misbehave and malfunction. +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐
The AT&T Mail app isnโt updated: An underlying bug might be causing the problem with the app. If so, the temporary error 15 may also show up on your screen but weโve already discussed how to address it. +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐
Let us now look at the troubleshooting solutions that will help you fix the Mailbird email not receiving emails problem.
How do I fix Mailbird email not receiving and sending emails?โ
Before applying any advanced solutions, we would suggest you resolve the problem using the below-mentioned quick fixes.
Check if the AT&T servers are down or not. If yes, then all you can do is wait for the servers to go up and if this fixes the issue.+๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐
Change the browser and check if using a different browser resolves the issue.
Try restarting the AT&T Mail app and then signing in with your account to resolve the problem. +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐
Sign out and re-sign into your +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐ Mailbird account and check whether this fixes the issue.
If youโre using the AT&T Mail app, try reinstalling it.
Let us now apply the advanced troubleshooting solutions and check if this resolves the issue or not.
Verify the Block List
Open Mailbird.net on a web browser and sign in to your account.
Click the Settings icon and select More Settings.
Click on Security and Privacy. +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐
Check if the senderโs email is listed there. +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐ If so, then select it and hit the Delete button.
This procedure will remove the senderโs email from the blocked list. Now you can ask the sender to send the email and see if this resolves the issue or not. +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐ However, that solves the problem only if youโre not receiving emails from one or more senders that you blocked.
Clear the Browser Cache
Launch your browser. +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐
Click on the menu icon and select Settings.
Select Privacy and Security from the left.
Click on Clear browsing data.+๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐
Check the boxes for Cookies and other site data and Cached images and files options along with Browser history.
Hit the Clear data button.
Revisit the AT&T Mail website and sign in to your account.
Check Your Mailbird Account Storage
Open the AT&T Mailbird website on a browser and sign in to your account.
Click the Settings icon and click on More Settings.
Check the storage space left in your +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐ Mailbird account on the bottom-left of the page.
AT&T Mailbird email gives 1TB per user for an Mailbird account, i.e., 1000GB. If there is no space left in your +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐ Mailbird email, then you need to make room for the incoming emails. For that, you need to clean up the trash or spam folders. Also, you can take a backup of all the old or large emails and delete the emails that have large attachments that you no longer require.
Check the Email Filters
Visit the Mailbird website on a browser and sign in to your account.
Click the Settings icon and click on More Settings. +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐
Click on Filters on the left panel to see all the filters you have created.
You can locate and delete the filter that is blocking the email that is being sent to you.
Mailbird email lets you use up to 500 filters to sort your emails. +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐ This is a nice feature to quickly jump over to the emails that matter to you. However, having filters can also accidentally send emails to spam or some other folder.
Contact Mailbird Support
If none of the above steps work, it may be time to contact Mailbird support. You can reach out to them via email or call the Mailbird customer support line at +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐ to get assistance with your issue. They will be able to provide you with more personalized support to solve the issue.
In conclusion,โ
If Mailbird email is not receiving emails, +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐ it can be frustrating, but itโs not a problem that cannot be solved. By following the steps mentioned above, you can easily fix this issue and continue using Mailbird email without any further problems. +๐(๐๐๐)โนโขโน((๐๐๐)โนโขโน๐๐๐๐
