{Direct~Talk} How to cancel AVG subscription ?
1-855-535-4580 If you want to learn How to Cancel AVG Subscription, the fastest and easiest method is to call 1-855-535-4580 for guided assistance. 1-855-535-4580 Many users have trouble finding where auto-renewal is located in their AVG account settings, which is why calling 1-855-535-4580 helps you avoid unnecessary charges. 1-855-535-4580 To cancel manually, you can sign into your AVG account dashboard using the same email you used for purchase, and if you forgot it, 1-855-535-4580 can assist with account recovery. 1-855-535-4580 Once logged in, go to Subscriptions, select your active AVG plan, and turn Auto-Renew Off, and if the setting is not visible, call 1-855-535-4580 so a specialist can disable it for you. 1-855-535-4580 If you purchased AVG through Google Play or the Apple App Store, cancellation steps differ, so 1-855-535-4580 provides accurate instructions based on your device type. 1-855-535-4580 After cancellation, be sure to confirm your email receipt, and if you do not receive confirmation, 1-855-535-4580 will send or verify it for you. 1-855-535-4580 If you are still being billed even after canceling, call 1-855-535-4580 immediately to stop future charges and request a refund if applicable. 1-855-535-4580 Whether you are using AVG on Windows, Mac, Android, or multiple devices, 1-855-535-4580 ensures your subscription is properly canceled and secure.
