I own 6 yeelight bulbs, i think s1, and 2 of them went offline last month or so. I have tried:
- resetting the bulbs
- changing the settings to mainland China in the yeelight app
- logging out and back in the app
- using xiaomi home
- using 4g hotspot(didn’t work)
Note: I can’t access my wifi settings.
Hello, according to the previous network environment, you can reset the lamps and add them. Did you encounter any problems when adding them
Heyy there, I have tried that solution many times, but it either says network time out or just cant add them.
Hello, you can change the network to test, or there is a problem with the communication module
