YLXD01YL connect to 110v
The YLXD01YL in the specifications says that it is 220v, but in the store they told me that I can connect it to 110v, can it be connected to 110v without problems and that it works well or risk of damaging the equipment?
Dear Mrogel013, it can be work running on by half the needed energy but somehow it will damage the device if u plug 220v into 110v outlet from time to time. It is recommend for you to hire HVAC electrician to convert the 110v to 220v in order for you to use the device. Hope this helps.
