Google Home and Assistant do not recognize the white light tones of Mi Bedside Lamp 2
For about 8 months the Xiaomi Mi Bedside Lamp 2 does not provide the correct white light tones if you ask for them through the Google Assistant or the Google Home application, instead it shows a faint mixture of RGB light.for example:
WHITE LIGHT:
Mi Home / Yeeelight: 5000
Google Home / Assistant: 255,153.0
COLD WHITE LIGHT:
Mi Home / Yeeelight: 6500
Google Home / Assistant: 255,255.0
WARM WHITE LIGHT:
Mi Home / Yeeelight: 3000
Google Home / Assistant: 255,128.0
I don’t know if this problem is due to a faulty firmware or a google problem, but when I first bought the device it worked correctly for about 4 months before this strange behavior.
The problem has been present with firmware versions 2.0.6_0030 and 2.0.6_0033. and according to what I have been able to verify in other forums, several users have the same problem with this and other devices:
Reddit:
https://www.reddit.com/r/googlehome/comments/kvq4gw/google_assistant_doesnt_know_what_white_lights_are/
https://www.reddit.com/r/googlehome/comments/gwrha4/so_when_i_say_change_lights_color_to_white_i_get/
Yeelight:
Please I appreciate that any representative of Xiaomi or Yeelight take note of the problem and provide a solution as soon as possible. Thank you.
