I have an YLXD50YL and have a problem that the ambilight color is not restored if it was saved in moon-mode.
Repro case, using the yeelight app (iOS):
- Select the little “up-arrow” icon and select “Default state”
- Select “Set default light”, select “Sun”, select “Ambilight/Color” and select a color -> save
- Turn the lamp off and on via the App -> Lamp starts in Sun mode with the Ambilight on in the correct color => OK.
- Select “Set default light”, select “Moon”, select “Ambilight/Color” and select a color -> save
- Turn the lamp off and on via the App -> Lamp starts in Moon-mode but with Ambilight off => BUG. The Ambilight settings should have been restored, just like how it works in Sun-mode.
I’m on firmware version “16” and no newer firmware is offered. It does look like there are newer firmware versions but those aren’t offered? My xiaomi id is 1875704593.
