I’ve seen a lot of the opposite happening with bulbs not connecting to Apple Homekit, but I have an issue with the bulb not connecting to the Yeelight app (iOS). To clarify, it does connect to the app at the very start, but if the bulb gets disconnected, it won’t reconnect to the App again, but can still be reconnected via Homekit.
The issue can be resolved by resetting, deleting the existing device and re-adding it, but it is not a permanent solution and I don’t want to keep doing this everytime my kid turns off the light with the light switch rather than the app. I can still control the bulb with Homekit, but I used scenes and customizations from the app which I cannot use anymore once the bulb disconnects.
Has anyone else had a similar issue and possibly a solution?
