老款吸顶灯固件为2.0.2_xxxx 仍然经常离线在此加白名单
小米ID:4615595
设备:Yeelight 皓石LED吸顶灯 Pro
当前固件版本:1.3.2_0021
现象1:丢包经常在35%左右,米家APP经常失联。晚上回家启动时经常闪,要10分钟左右才能稳定。麻烦加白名单,感谢。
Hello
ID 1916633266
YEELINK.Light.ceiling5
I restart the lamps everyday and they disconnect a few hours ago.
This is happening since the last firmware updating a couple of months algo.
Yeelink.light.ceiling4 2.0.2_0056
The scenes for ambient lighting have been missing since the last update. have been replaced by the main scenes. but there are also some missing and there are several doubles.
小米id:1401297836 大概一个多月前出现经常自动离线。重新通电就又正常。随机运气不好又会自动掉线
Mi ID 1592849618
Device YLXD02YL (650 yeelink.light.ceiling4)
frequent offline started about a month ago. remote control stops working.
@rex_yan1 could you help us? My ceiling lamps go offline after restarting. Its been 4 months without any solution
@liufei @EricJiang is someone of Yeelight answering? Because I only read complains and no solutions.
After 13 months with the issue and no answer in the forum, I have 2 expensive ceiling lights that I cannot use because they disconnect from wifi and the technical solution is “buy a new one”. Of course, they are telling me this now, after the guarantee expired. Thank you Yeelight for your great support. I will never buy a thing from you again.
1
家里的5个吸顶灯已经有2个连不上网关了,只有遥控器能操作,麻烦看看有没有解决办法,小米ID:22862082
yeelink.light.ceiling38
YLXD45
MAC : CCB5D151D993
产品model:yeelink.light.ceiling2
​小米ID:154607027
​固件一直留在1.5.9_0034,没有收到新的更新,在米家戓yeelightAPP都提示最新版本,当前版本很容易掉线,只有断开电源重启修复非常麻烦,如有可能请推送新的固件给我,请将我的ID加入白名单,谢谢。
112185942 一直掉线 有没有办法 现在是2.0.2_0048 设备ID:99587432
