Hi, I ordered 3 Yeelight YLXD39YL 50W LED Ceiling Light 450 (Xiaomi Ecosystem Product) - Starry Lampshade. Two lamps work well. The third lamp does not work well. I enclose a photo in the attachment. There are 3 led parts in the lamp. The two LED parts change color together. The third LED part changes color in reverse. When I set the lamp to be on warm white, the two LEDs light up warm white and the third LED part light up cold white. When I set the lamp to be on cold white, the two LEDs light up cold white and the third LED part light up warm white. I found that the third LED strip is connected in the opposite way as in the other lamps by short white cables with connectors. The cables, on the other hand, are crossed. Can you send me a short white cable with connectors that is connected properly so I can replace it?
