Another connection issue thread with lots of research and will to help and test!
Hello,
Thanks for the quick answers.
I can imagine, that it would need intensive testing before releasing it to that many devices around the globe. I would be more than happy to recieve the update and test it also on my side. My MI ID is: 6382797779
Regarding the thing you want to be sure, I’m more than happy to answer that.
So HA starts an asyncronous request.
So when it sends out GET_PROP it sends it with ID and expecting an answer with the same ID. If in the meantime other notifications come in it will just process them without affecting this request.
So, no. It will no deem it as a fault.
Given that we have such good communication, there is 1 more issue with the firmware which should be adressed and you can replicate easily which I just remembered.
Just unplug the WIFI and plug it back in. The bulb will not reconnect till next physical power off and on.
The real world scenario is:
There is a electrical outage. The bulb firmware will load in maybe 3 seconds whereas most ISP Home routers will take at least 1 minute.
If I’m not mistaken you are using EPS 8266 or somethin similar in the bulb.
You could simply check for WIFI and reconnect in the loop(){} function. That’s what I am doing with all my custom sensors and devices. It might be resource intensive to implement it on every loop, but could for example time it. Like once every minute or something like this.
Maybe there is actually an reconnect function and I didn’t wait enough? Not sure.
It is not reallly, really big issue for me, but imagine using only Yeelight bulbs in a big project. Let’s say you have a hotel. Imagine having to go around the building switching off all bulbs on and off. You could solve it by mounting “Smart wall switches” and fire off on procedure if bulbs are not responsive just like @com_wolf (Another connection issue thread with lots of research and will to help and test!) mentioned above , but again this would be an additional investment (again, imagine a hotel, can get very expensive), which can be solved, maybe by a few lines of code.
best regards,
Thomas
