It is working fine from the Yeelight app but it is not detected in Mi Home. I want to use Mi Home because I would like to use my bulb along with my Mi Control Hub (DGNWG05LM).
I’m using Germany server, and I choose “Yeelight LED Bulb (Color)”, is it the right way to do it?
Is the bulb from China? If yes, it is for China region. It works with Yeelight app because Yeelight doesn’t impose region lock. But Xiaomi does, so it is not in Mihome. You’d have to use it on Chinese server in order to see it in both apps.
I’ve bought the bulb in France ( https://www.amazon.fr/gp/product/B07C62QWGB ), it says “compatible with Mijia”. If I set the parameters to China region in Mi Home, then it seems it cannot recognize neither my hub or my bulb.
In the China region the bulb is called “…1S”. You might be out of luck because your hub may be EU region. A workaround is using homekit but that requires the Aqara hub.
