i have Mijia Bedside Lamp 2. I have configured Nightlight mode to be active from 22:00-07:00. I have noticed that the lamp color the first time i have switched it on after nightlight mode is set to green. How can i change this default color? I’d like to have it set to white.
Which light do you use before nightlight mode?
Before nightlight mode i use white mode. I also have noticed this morning that the lamp does not use green by default, it is green because current color mode color was set to green. So apparently after nightlight mode the lamp switches to color mode and not back to white mode like it was before nightlight mode. The question is: How to change that?
It seems this is a bug, I will have a check and feedback to engineer to fix. Thanks
