Yeelight desk lamp + ceiling light + Aqara Hub
I get the Aqara Hub and the Yeelight table lamp and the ceiling lamp for the test. When I turn the lights on or off with the Aqara wall switch; sometimes only one of the lamps turns on or off. Is there any way to fix this? Both should turn on/off at the same time.
You can create a manual automation to test if it works.
