Accessory not found error occurs every time I try to add the light bulb to Apple Home. I bought two light bulbs and was only able to add one of them to the Home app.
hi there, did you fix this problem cause I am having the same issues.
I found a workaround to add 2 light bulbs. I just used the Yeelight app to control my first light bulb then used Xiaomi home to control the second light bulb. I add both of them to Apple Home and now I can control them from here.
thanks for your reply, how do you add from Xiaomi home cause I can’t find that option
