Yeelight JIAOYUE 480 is not working
Recently my Yeelight JIAOYUE 480 ceiling lamp was stop working. It didn’t turn on anymore. I just heard some high frequency clicks noise. It’s not software issue.
I disassembled and found the root cause. One of LED driver IC chip was burned.
As result the chip did short circuit by the main power line (36v) and the main power supply was in protected mode by overcurrent.
When I disconneced the secondary winding of transformer from the low voltage part, and tested lamp again, the noise was disappeared. I removed the burned chip from the PCB, connected low voltage part.
And tested again, the lamp is turned on. It was controlled over remote or wifi. But only cold LEDs are working, as expected. Because the second LED driver is not work.
Could you contact with technical support and provide more details for replacement part?
See attached photo of the chip. I suppose it called “AZTAPB” in so-8 package.
But I can’t find any replacement for it. Can you provide alternative Part No/Marking for this chip?
Best regards,
Eugeny
Hi
The Part No. of the chip is SY8745FCC. Pls find attached pic for more info about the chip.
Hello, @HuangXiangyi
Thank you for quick response. Yes, it exactly what I need.
Also I found one diode (D7) which is punctured. It conducts the current in both ways. Could you please help me to find part no. for this diode? The SMD marking code is 26.
Diode parameter:2A 60V, SOD-123, Part No.:FM260-M.
Thanks a lot!
